<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Application failed to start</title><link>https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/f/contextcapture-descartes-pointools-forum/230998/application-failed-to-start</link><description>I have just got this error when opening up the Context Capture Software:
 This application failed to start because Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
 Available platform plugins are; minimal</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Application failed to start</title><link>https://communities.bentley.com/thread/715816?ContentTypeID=1</link><pubDate>Thu, 09 Jun 2022 11:19:03 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:d584bea6-01a1-4d4b-b827-ee48ab9b119e</guid><dc:creator>Felix James</dc:creator><description>&lt;p&gt;Please try the following:&lt;/p&gt;
&lt;p&gt;&amp;nbsp;&lt;/p&gt;
&lt;p&gt;First: Make a clean software reinstallation and ensure the installer you have got is not corrupted.&lt;/p&gt;
&lt;ol&gt;
&lt;li&gt;uninstall the software from windows &amp;ldquo;Add/Remove programs&amp;rdquo;&lt;/li&gt;
&lt;li&gt;important: &lt;u&gt;remove manually all installation files&lt;/u&gt; (C:\Program Files\Bentley\ContextCapture)&lt;/li&gt;
&lt;li&gt;download again and reinstall the latest software version&lt;/li&gt;
&lt;/ol&gt;
&lt;p&gt;If the problem persists, try this 2&lt;sup&gt;nd&lt;/sup&gt; option:&lt;/p&gt;
&lt;p&gt;Another possible issue is that PATH environment variable has been changed on the&amp;nbsp;your system by another application, and gives priority to another version of QT DLL dependencies.&lt;/p&gt;
&lt;p&gt;Please follow this process to list DLL paths or the running viewer process:&lt;/p&gt;
&lt;ol&gt;
&lt;li&gt;download Microsoft ListDLLs from &lt;a href="https://docs.microsoft.com/en-us/sysinternals/downloads/listdlls"&gt;https://docs.microsoft.com/en-us/sysinternals/downloads/listdlls&lt;/a&gt;&lt;/li&gt;
&lt;li&gt;create a working folder, for instance C:\test_DLL&lt;/li&gt;
&lt;li&gt;copy &amp;ldquo;Listdlls64.exe&amp;rdquo; in this folder&lt;/li&gt;
&lt;li&gt;open a windows &amp;ldquo;Command prompt&amp;rdquo; in this folder&lt;/li&gt;
&lt;/ol&gt;
&lt;p&gt;(from windows explorer, type &amp;ldquo;cmd&amp;rdquo; in the Address field)&lt;/p&gt;
&lt;p&gt;&lt;img alt=" " src="/resized-image/__size/640x480/__key/communityserver-discussions-components-files/343228/for_5F00_communities.png" /&gt;&lt;/p&gt;
&lt;ol&gt;
&lt;li&gt;Launch ContextCapture Master and leave it opened&lt;/li&gt;
&lt;li&gt;From the command prompt, type &amp;ldquo;Listdlls64 CCMaster &amp;gt; output.txt&amp;rdquo;&lt;/li&gt;
&lt;/ol&gt;
&lt;p&gt;A file &amp;ldquo;output.txt&amp;rdquo; is created in the folder, it lists all the DLLs loaded by the application, including their path, you can send it to us for analysis.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
