Hi expert,
May i know how to merge the FBX files into single file, like point cloud and SLPK features in CC Master.
In the Production Definition > Format / Options for format Autodesk FBX, under Level of Detail (LOD) enable the option "Generate LOD across tiles".
Hi Felix, i done produced the FBX across tiles as your suggested, but fbx files is produced to separated files. My colleague is request fbx only single FBX format file, to open it using Autodesk Naviswork easily. Such as the orthophoto merge file and slpk previously merge features in CC Master.
Thank you for your clear answer.wordle unlimited
