Hi.
I received this warning when I tried to import the point cloud and trajectory file. Does anyone know how to fix this? I extracted the trajectory file from the same las file.
Had not seen any example where this trajectory import worked all requires manualy update timestamps or do other rituals.
Hello Nurin,
This warning tells you that the timestamps stored in the las file are vastly different from the ones in your trajectory file. Make sure that you are correctly setting the columns when importing the trajectory. You can use LASTools to inspect more deeply your LAS file and check what the timestamps are.
Cyril
