ccmasterkernal process to import photo pose data from csv
I have been using CC successfully, and now I'm trying to transition to the python script. Our current process involves importing the image pose data from a csv file in a local northing easting elevation format. However I cant find a python command to import just the pose data. I tried to use the import_txt.py but it will only create a relative block and not hold the pose data. Has anyone got the ccmasterkernel to work with an arbitrary local coordinate system in feet?
