I've tried to reinstall CC etc but same result on any CC project.
Cheers,
Michael
Hello Michael,
This seems to be a long path issue, or an access right issue. First, can you check that this file exists and is accessible through the regular Windows Explorer? Second, can you open the Registry Editor tool (open start menu and type regedit), go to Computer/HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/FileSystem and check that LongPathsEnabled value is set to 1:
Thanks, Cyril
Thanks a lot Cyril,
I've figured it after few days. I've encountered a similar issue few years ago under a different error code.
I'll check Long Path.
I have this issue as well. I checked the file location given in CC Engine, and it appears the production file doesn't exist within the temp folder. Any ideas?
Hi Cyril,
Can you please share the solution that worked for you? I am having the same issue. The LongPathsEnabled value is already set to 1 for me.
Thanks, Greg
