I'm trying to open some projects I created in Contextcapture, they open fine, however, I'm not able to see any 3D views of the productions in these projects. CC says that the production is not available because the file is not accessible.
That usually means that you have moved the project to another location and CC can no longer find it.
Hi Scott, Yes you are right. Yesterday after I posted the question, I realized that I moved the master folder that had all my CC projects. I had to fix all the links manually.
