Hello
Please can you advise:
The version of MicroStation CONNECT version I have installed on my laptop is the CONNECT Edition Update 13 - Version 10.13.00.48
Do you know if the Bentley Descartes CONNECT Edition update 17 10.17.00.115 would be compactible with the CONNECT Edition I have installed on my laptop? If not, what would be the appropriate version of Bentley Descartes I should request.
Thanks in advance.
Kind regards
Joe K
Descartes for MicroStation CONNECT is a companion product for MicroStation It is included with the MicroStation installer so there is no longer a compatibility question. You must enable Descartes in your MicroStation installation. Please see the link below for details:
(+) Descartes Companion CONNECT Edition Installation - ContextCapture | Descartes | Pointools | Orbit Wiki - ContextCapture | Descartes | Pointools | Orbit - Bentley Communities
Answer Verified By: Bruneau St-Jean
