I am using ContextCapture Center edition (Update 20.1 - v10.20.1.5562) and have been starting to experience issues in the last week (was running previous version when the issues started) of the job queue data base file locking when I open another engine on my network. When this file appears, whatever process is running - both ATs and Reconstructions - seem unable to access the job queue ('Job Queue Not Reachable') and it goes back to 'Pending,' and then the job queue monitor will show 0 engines.
Right now, I have quite a large Reconstruction which I'm able to build using only this computer's engine. I can't recall if this issue has happened when I have only been running an Aerotriangulation only. It seems to be a problem mostly when I am doing reconstructions, or at least this is when I have noticed it.
A few notes:
As an update - this problem only occurred when I selected regular volumetric grid as the tiling for the reconstruction. I tried quite a few different tile sizes, and it seemed like it didn't make a huge difference. I suspect this had something to do with too much read/write traffic on my network. When I reverted to my standard setting of 'adaptive tiling' this problem immediately resolved itself.
