Hi, as in the subject, we cannot attach 3SM from PW ContextShare to a dgn in OpenRoads Designer (2021R2) as ORD shows error: "This Reality Mesh needs to be reprojected but no GCS is set" and gets listed in red in Reality Mesh Attachments dialog. The mesh has been produced in ContextCapture 20 (CC) with a GCS plus local geoid vertical datum. The dgn has the same GCS and geoid assigned. Upload to PW ContextShare done from within CC. All looks fine in Reality Data Web Viewer and in iTwin. Other 3SM attached the same way to the same dgn works fine when produced in CC19.
Has anyone seen similar issues?
Mariusz
Thanks Oto for your suggestions. I guess we will see how this investigation develops further.
OpenRoads Designer 2022 R1
