hello, and happy new year.
A reconstruction of a block has two tiles that failed because of insufficient memory for processing.
The other tiles are computed and as I see in the job details the las files are exported. Where are these tiles?
I had checked to merge the cloud which is not happened because of the failed tasks.
Is it possible to get the computed tiles and make another reconstruction only in the failed part?
I am able to see the model in spatial framework window
Thank you
ok, I found it. I make another production in the same reconstruction without checking the merge option.
