For Aerotriangulation... how can I force CC to use the positional information for WGS84 GPS coordinates and NOT let CC change those locations under any circumstance? I am fine with rotation or other details changing, but the coords are not being respected. We have a metadata file that has locations for every image. The locations have been verified outside of CC. If we process a small area, it seems to work. The larger the area, the worse the results.
Orange is (ironically) ground truth and are the images that were unable to be used. Green is what we end up with.
This is from a run of approximately 10,000 imagesHere are my AT settings:
A. Positioning/georeferencing:- Adjustment constraints: photo positioning metadata- Final rigid registration position: photo positioning metadata- Final rigid registration orientation: none- Final rigid registration scale: none
B. Main settings:- Key point density: Normal- Tags or QR Codes extraction: Disabled- Pair selection mode: Default- Color correction: blockwise- Splats: Enabled
C. Estimation policies:- Tie points: Compute- Position: Compute- Rotation: Compute- Pre-calibration stage: Enabled- Focal length: Adjust- Principal point: Adjust- Radial distortion: Adjust- Tangential distortion: Adjust- Aspect ratio: Keep- Skew: Keep
Just wondering why I could be doing wrong. Thanks
Sorry if I implied they were perfect or near perfect. I didn't expect them to move so much. They are standard GPS coordinates and are of reasonable enough accuracy from what I can tell.I will also try the Legacy Engine option in addition to "maximum position metadata confidence.cfg." I just need to find out where that is.
It is under presets - "C:\Program Files\Bentley\ContextCapture\data\Presets\AT\Legacy engine.cfg"
You have to import in last step in AT Settings window.
