Production_1 - Tile_+005_+006.zip
Can you confirm the the following file exists?
H:/山美建模/2023-3-8-12#-2/20230308 12-2/20230308-12-2\Project files\Block_12\blockwise_color_equalization.bin
If it does please try removing the Unicode characters from the file path. The special characters my be causing a problem. You care currently using ContextCapture Update 18. We would recommend installing the latest version (Update 20 ) which has better support for Unicode.
