I am having a trouble to produce contour using TerraModeler. In the last produce contour dialog cannot save. The step that I use:
Setting contour keypoint in TerraScan > setting for display contour > setting in label peaks and pits > for TerraModeler > Surface > Utility > Produce Contour.
After produce contour step the surface missing on the terramodeler window and contour not show.
If you have any solution can share with me.
Thanks you,
Fazirah
