For some reason, the rotation values for the photos I took using my Zenmuse XT2 Thermal camera are "unknown". I've used the same camera in the past and ContextCapture was always able to recognize the rotation values. Any idea why this is happening?
Check with exiftool if there are values in metadata.
Once I completed the AT process the rotation values appeared on the Pose section!
Because Contextcapture can work without rotations and it calculates it later. But you should find out why pose from metadata didn't work at import.
