I have created all the productions such as the mesh and las pointclouds. When I try and use the ground extraction tools in 2023 it gets to 2% and will not budge. When checking the engine there is nothing running.
I've try several different ways to run the ground extraction process and all have the same results.
Any suggestions?
CC ground extract doesn't seem to recognize road and slope as ground points.
