I have created all the productions such as the mesh and las pointclouds. When I try and use the ground extraction tools in 2023 it gets to 2% and will not budge. When checking the engine there is nothing running.
I've try several different ways to run the ground extraction process and all have the same results.
Any suggestions?
In our case the resultant .las had to be run through LasTools las2las.exe with the -rescale 0.01 0.01 0.01 -reoffset 0 0 0 to become useable in other software packages like LP360 and ArcGis Pro. Hope this may help others.
CC ground extract doesn't seem to recognize road and slope as ground points.
