Hello, Sorry if its a wrong forum thread, but I am very new to bentley, and I can't seem to understand why according to tutorial that I am watching I can't follow steps that they provide to do an ortophoto section for facades? It I can't do merge, it does not show anything, only element selection and thats it. What could be the problem or what do I need to do?
Thank you.
I believe that there is a known bug with creating orthos of facades from a .3mx. The current work around is to convert the .3mx into a .3sm and then do the merge. If you don't know where the convert tool is post back and I'll look to see which tab it's under and let you know. You are trying the right tool and it will work.
You need to use merge Raster tool and as mentioned better from 3sm as 3mx may not work because of outstanding backlog item(bug) for years.
