The context capture is not recognizing the correct height of the bridge deck , firstly I added the tie points on photos and in one AT I got the right height of the bridge deck, but after I added more tie points I only got results with the bridge deck at wrong height.It is important to say that the photos when were taken the shots were not associated with a georreference or geolocalization system, like a GPS, that´s why the use of tie points.The attachments include the settings used to proceed to AT, and images of the results with the bridge deck in the right place and another, after the adition of more tie points, in the wrong place.
What should I do to solve this issue?
Hi Oto, Since June I created the fake GCP's, but I'm having some trouble to aerotriangulate, the settings that I used and other attemps failed.
Would you suggest any settings to use in this case that I have to consider Tie points, fake GCP's and can't count on metadata?
Most likely all will fail because it can't correctly align photos for such use case. It is too tricky object so will need to refly with more photos further away from bridge.
