I've been trying to untangle this for the past two hours. I can't make a service request because I don't have an account and none of the links to download the viewer work. Ideally, I need an iteration of the viewer that does not require the updated connection client, but that does run on windows 10. Thank you in advance,John
You need Contextcapture Update 10 or Acute3D 4.4.10.336 Viewer(a3dv040410336en_updt10) which are less greedy and works without login. Alternative is to use other formats like OSGB(OpenSceneGraph) which has opensource viewer.
