Editing cits in a dgn in Descartes
I have two cits in one dgn. They are the same cit. I need to edit one cit but leave the orginal unedited. The client does not want me to change the name of either cit. The names have to remain the same.  Is there  a way to lock one of the cit "copies" in the file and do my edits to the other without changing the original?  I know when I make the copy of the cit, in Raster Manager, the cit file name is copied exactly.
Thanks for your help
  • Hi,
     You will need to make a copy of the raster on your hard drive (copy it to a subfolder to keep the same name) and then attach both raster images in Raster Manager.
     If you copy a raster that is already attached in Raster Manager, it creates a copy of the same raster attachment and any modification would then be applied to both attachments.
     If you want to lock one of the images, use the "Lock" field in the "Extended" pane of the Element Information dialog.
     Pascal
     This is a test
Reply
  • Hi,
     Pascal
     This is a test
