Hello
Is there a way to check and change the dpi of a cit raster image in Descartes?
Glenn
Hi Glenn,
In the raster element properties shown in the Element Information dialog you can change the DPI but that will not increase the number of pixels in your image.
If you want to increase the number of pixels in your CIT image you can use Descartes` merge tool. Just select the corner of your CIT image as the merge area and set the pixel size that you want in the Merge Options dialog.
Mathieu
