Old Microstation 95 developer here . Our office is in the midst of upgrading from 95 to Map Enterprise/ Descartes. We're still very confused about Geospatial Admin / Schema. I'm less concerned with creating a schema and more concerned with how to use it. If were going to be attaching shapefiles as reference files when exactly does the schema work it's magic? When we attach the reference shapefiles there's nothing that says "Apply schema".
Yes, for now that may work. In the class I do not recommend using this as a regularly. There has been discussions of removing this since at times it is not reliable.
Jerry
Good to know. Is there another (recommended) way for dynamically re-loading the schema? It's a huge pain to have to re-start Bentley Map each time we make a tweak to the schema. Thanks.
Yes, there is a method to the madness.
I would recommend.
Always remember, that yo do not need to "Export" all workspaces and metadata all the time. You can export the feature meta data separate from the workspaces, etc.
sorry meta instead of meat. Typo.
