hello everybody
i have been using bentley descartes for 2months now, and i still find some difficulty with geo-referencing with the software. I hav a raster with me dat i want to geo-reference. The raster has coordinate points (like 740500N, 533800E and so on). i have already vectorized it (thou i know it wld hav been better if i had geo-referenced the raster b4 vectorizing).......i nw wanna georeference the vector data with d coordinates on d raster.......
wld appreciate if someone can explain hw i shld go bout it in a simplified manner, so i wld get it once and for all....
Regards dipson(Assistant Product Manager)
Computer Designs System Services Nig Ltd (Bentley Partner in Nigeria)
Hi Dipson,
First I find it strange that the geo-referenced image was not located in the rectangle after the registering process. Maybe sister file created was not used according to your Raster Manager related preferences?
Descartes can only geo-reference images. But according to your coordinate you should be able to use standard MicroStation moving and scaling tools to position your vector and your raster correctly without using Bentley Descartes' register tool.
Here is an video showing how to place your raster with some vector on it using standard MicroStation move and scale tool :
Finally for the blank image the 4pts or + projective requires that at least 4 pair of points linearly independent (e.g. : not co-linear) be specified. But according to your coordinates using a projective transformation is not recommended. A 2 pts or + similitude transform should do the trick.
HTH,
Mathieu
