Descartes 'Stamp Vector' with point cloud
I would like to use the stamp vector tool to burn pointcloud images (pod data) onto a raster.
It seems to crash every time I attempt it. Can someone confirm if this is possible or not?
Mike H
  • Hi Mike,
    Thanks for the suggestion to add the "Point Clouds Only" setting in the "Elements to Process" list. I have filed CR341258.
    There are two things you can try to get better results when you are zoomed in close.
    1) The "Match Line Mapping Settings" . If you are familiar with the "Stamp" tool, you will know that you must use the "Match Line Mapping Settings" tool after you have modified your view's zoom level. If you are not getting expected results, use "Match Line Mapping Settings", restart the Merge tool, make sure "Use Line Mapping" is toggled ON and recreate a new output raster.
    2) Increase the resolution. If you are seeing the pixels in the result, it means your resolution may not be high enough. To get good results, you should need several pixels in the raster to represent one Point.
    HTH,
    Pascal
     This is a test
