Descartes SS4 for Microstation only as platform
Will we get a Descartes SS4, which we can install at a Microstation SS3 ? - If Powerdraft is a certified platform - why not Microstation ?
  • Hi Reimo,
    This is a question to ask the Bentley support, but as I see you may download a "Standalone" Descartes SS4"!
    Frank
    since 1985: GIS, CAD, Engineering (Civil)  Senior Consultant : [Autodesk Civil 3D , Esri ArcGIS, VertiGIS: in previous days : Bentley MS V4 - V8i, GeoGraphics, Bentley Map V8i, InRoads,  HHK Geograf, IBr DAVID] :  Dev: [C, C++, .NET, Java, SQL, FORTRAN, UML]
    [direct quote by: http://en.wikipedia.org/wiki/Helmut_Schmidt]: "Wer Kritik übel nimmt, hat etwas zu verbergen"
    Wer Grammatik- und/oder Rechtschreibfehler findet, der darf sie behalten :-)
  • Hi Reimo,
    There will be a MicroStation SS4 available in the upcoming months to use with Descartes SELECTSeries 4 (see www.bentley.com/.../descartes+ss4.htm for more information).
    Mathieu
  • Well, of course I have asked Support first, but until now, they were not able to answer.
    The question about the Standalone Descartes SS4 would be, if that is a different product (probably), which is not covered by the Select contract of exisiting Descartes customers.
    Furthermore, today in the morning, a download of Descartes SS4 and a special MS version (SS3 Update 1) appears for Select Download:
    Bentley Descartes V8i
    08.11.09.432
    Dependencies:
    MicroStation V8i
    08.11.09.397
    But the readme continues to display this:
    This Descartes version cannot be installed on MicroStation V8i SS3.
    But it can be installed over one of the following Bentley products:
    PowerDraft 08.11.09.397 or higher
    AECOSIMBuildingDesigner 08.11.09.547 or higher
    OpenPlantModeler 08.11.09.278 or higher
    PowerCivil 08.11.07.600 or higher
    PowerCivil for North America 08.11.07.600 or higher
    PowerInroads 08.11.07.605 or higher
    PowerGeopak 08.11.07.605 or higher
    PowerSurvey 08.11.07.605 or higher
    PowerRailTrack 08.11.07.605 or higher
    MXROADS 08.11.09.000 or higher
    BentleyUtilitiesDesigner 08.11.09.31 or higher
    So I hope, this is an error in the readme, which is repeated in various other Bentley Documents at the Website, since none is certifiying MS as Platform.
    Maybe the product Manager could clarify the situation ?
  • Hi Reimo,
    Up until yesterday there were no available version of MS that were compatible with Descartes SS4. The version of MS I added as Descartes dependency (MS 08.11.09.397) is newly available for Descartes users and can only be obtained when downloading Descartes SS4.
    The readme is my error, I should have change the readme yesterday. I will do that shortly.
    You can safely use Descartes SS4 on this MicroStation. The same Descartes will also be compatible when an MS SS4 will be released.
    About Descartes Standalone, You were right, it require a different license and you cannot be used with your old Descartes license. Descartes Standalone is more expensive and does include a full version of MicroStation.
    Yves Boivin
    Product Manager, GeoSpatial Desktop Products
