Today I finally got around to setting up dgnlib with our common point cloud presentation settings. So we don't need to set it up for each file.But does not work.
Was it not intended for presentation styles to be configurable in DGNLIBS?
Mike H
As a workaround, you can create/define point cloud presentation settings in a separate file, and import them into your active file.
Hi Mike,
I have asked product management and it seems that the point cloud presentation settings are not supposed to work with DGNLIBS.
So you should use the Import mechanism referred to by Inga instead.
Mathieu
Thank you Inga and Mathieu
Thanks for the suggestion of importing. I looked for keyins to do the same, but unfortunately none exist. No vba interface either. So we have to do this manually and follow all the prompts.
It would be nice if at least the Presentation styles were configurable in dgnlibs as this would be consistent with 'Display Styles' etc.
I can understand the other 'Point Cloud Presentation' tools ie Sections, Model by Section,Clips etc which are Descartes specific having there own mechanism. But I think 'Presentation Styles' should live in dgnlibs.
Mike
