Hi Forumtrying to import a Leica .bin point cloud into AECOSim V.08.11.09.593 SS4 and the conversion process allows me to open the conversion box, but them once i allow it to convert, what looks like from the .bin to a .pod file, it says 'Convert Failed'.2 screen shots to follow. SS1 below shows an error about different units. This .bin point cloud is a from a client so initially i thought i'll change my working file this is being imported into [its blank] so the untis match. did this now it says: 'Convert Failed' again, but i dont see any clues on how what or why? Any help?
It seems that this is a bug, so I have entered bug TFS #24360.
Mathieu
Best,
Adam
OpenRoads Designer 2023 | OpenRail Designer 2023
I'm running into a conversion issue with my las file. Since you mentioned that it is a geolocation issue, I wonder if I can just delete or somehow modify the geocoding in the header to correct the issue.
