I currently have multiple layers in a Pointools project that are different pathways. Is there a way to use scripting along with the notes to turn the color of the layer on and off or turn the layer itself on and off? Essentially I would like to click the note that says "Take route 1" and route 1 would change color so the user can now follow that path. I cannot find a lot of info regarding scripting in Pointools but know the option is there.
Hi Nick, I would say this is very much possible - apologies for the delay i'm just trying to get hold of the expert on this matter so we can have his input. I will get back to you in a few days.
thanks, Dan
You can create a note with a hyperlink to a Pointools .ptl file that has the desired path. Choose Hyperlink to "file (relative)" You will have one ptl file that has a note for each path plus a sperate ptl file for each individual path.
