As you may know Bentley Descartes V8i (SELECTseries 5) has been released a few months ago.
There is now short videos demonstrating each of the new functionalities in this release (see the section Bentley Descartes V8i (SELECTseries 5) ).
Mathieu
which files extension for Point-Cloud are readable ?
is any of those formats supported : pts , zfs ?
thanks
Microstation only supports the .pod file format, but we do support a lot of file type in Microstation so you can create pod files frome these files. The list of supported format is : .bin, .cl3, .fls, .fws, .las, .ptg, .pts, .ptx, .3dd, .rxp, .rps, .xyz, .ixf, .e57, .txt
There's also a small software named Pod Creator (www.bentley.com/.../Bentley+Pointools+PODcreator.htm) that allow you to impot multiple format to POD files.
HTH,
Daniel
