Hi there,
There are very old post of users complaining about the fact that PodCreator does not import the intensities from cloud text files that contains them.
Since all this time I can't believe that this issue (among others as well) is still not solved.
I am very very disapointed by the situation now that Pointools is part of Bentley.. Price has been multplied and the bugs are always still present..
Please, solving the bugs IS A PRIORITY !
Fred
Hi Fred,
What build of the PODCreator are you using?
Answer Verified By: Ben Fredericque
I just tried it with the latest POD Creator version (2.00.01.2 )that is on SELECT server and on bentley iware page (www.bentley.com/.../bentley%20iware.htm) and it works fine for me.
We updated POD Creator earlier in 2013, we addressed several bugs and updated some partner libraries.
Ben
Hi Felix, Ben.
Hope you are OK ;-)
Well of course the way of writing in my post was caused by the long-time frustration to see issues and bug that remains unsolved since years.. And before writing that in that way I checked with the latest build I downloaded the same day (4 feb. 2014) and the build has the number 02.00.01.02, Build 2.0130618.
I just made the test again, and I confirm that there is an issue with intensity reading, compared to the way Pointools succeed to import them. Did I missed something ?
Here are the screenshots showing the process .
As you can see, at left displays the cloud with intensities imported by Pointools, at right the same cloud through PODCREATOR.
I spent again time to document the problem, as many times in the past for other issues, and they are still unsolved. I become a bit lazy now.. Hope you can understand that.
If you want me to upload the XYZ ascii file, please explain how I may upload the file, I can't find the option.
Thank you.
Fred,
seems we have 2 issues here:
1) an import issue we are not able to reproduce
2) other issues that you are referring at that seems to not be tracked properly.
Please provide me with the dasaset (benoit.fredericque@bentley.com), I will check it and follow-up with you personnaly on the 2 aspects.
