I have a JPEG file attached in MicroStation. When I use the cut command to a portion of the file it leaves a white rectangle. How can I make it black like the background in MicroStation?
Descartes SS3
thanks
Here is how to do it:
1) Open the "Transparency and Background Color Settings" dialog (Raster Manager > Utilities > Descartes Attachment...).
2) In the "Background Color" section, select the color you want to assign to the cut area.
3) In the "Image/Background Color" section, select the raster you want to assign that color to.
4) Click the "Assign >>" buttom.
HTH,
Pascal
Answer Verified By: B Stuart
Thanks Pascal.
Is there a way I can set this for all my hybrid files using JPEG's
Brian
Hi Brian,
The dialog Pascal described supports multiple selection. So one way would be to select all your hybrid JPEG and set the same background for all of them.
Mathieu
thanks Mathieu
