Hello.
I'm working in Descartes V8i SS5. I'm classifying a point cloud. When I start the edit classification tool, I cannot change the source class from "all classes". I can change the destination, but it alwasys pulls the points from "all classes". Anyone else run into this issue.
Thanks!
How are you trying to change the selection of the Source? In the drop down list you should deselect each of the classes that you do not want. Each selected class has a black dot to its right. You should click on each dot to deselect it. Once you have done this the Source options displayed should change..
The 'Source' list does not operate the same as the Destination list. As Felix mentions. you need to click the wee black dots to select or unselect specific classifications. It's not good enough to just click on the names. Likewise, it doesn't support CTRL+click or SHIFT+Click to select multiple classifications.
Unfortunately, this is a known issue in Descartes 08.11.09.578 (Defect #83127) which will be fixed in the next maintenance release of Bentley Descartes.
In the meantime, you can use Descartes 08.11.09.541.
Pascal
Answer Verified By: Emilio Ramirez
Thank you all for your input! I had already uninstalled Descartes for other reasons prior to seeing the first two posts. I have installed the 08.11.09.541 version and it works.
