We have 21 separate ecw files that span a total of ~8200km² we want to merge them into a single ecw using descartes.The files are in EPSG:3395 (WGS 84 World Mecator)
we have...Batch converted them to uncompressed iTiff64 (using average pixel size of 0.15m) The total size being 551GB. Amazingly despite the size this all references into a dgn extremely quickly and load times are next to nothing!
Now we are in the process of Merging to a single iTiff64 using the descartes 'merge' tool. With the intention of then re projecting to another coordinate system and merging out to ecw. But this process is taking for ever.
After two weeks the resultant iTiff64 is only 32GB and from experience when using no compression the resultant merged file will be approximately the sum of the source iTiff's. Meaning it won't complete for another ~120 days!
'Resource Monitor' is reporting a write speed of 25mB/s (which should give us a better result) memory usage is only 2.3GB the source files are on one dedicated local drive and the destination file is on another.
I have had success in the past with areas as large as 50km² within reasonable time.Is this just too big for Descartes?
Mike
Hi Mike,
I just did a test doing a merge of about 100 compressed TIFF files (total size of about 5 GB) to create a huge around 390 uncompressed GB iTIFF64 file.
I didn't let the process terminated since I don't have that free space, but in 14 minutes my iTIFF64 file had already 37 GB of data.
Note that my computer is about 3 years old, no Solid State Drive in it.
The source and destination files were on the same magnetic hard drive.
So I'm suspecting that there is some computer problem involved. By two dedicated local drives, do you mean external USB drives? That could be causing the problem.
You also mention that you are also running another instance of Bentley Map Entreprise. Me during the Merge my computer went so slow that I could barely do another thing. So it seems the transfer of pixel data is not using as much computer resource as mine.
I would thus suggest that you drive doing a smaller merge (10-15 GB) directly with everything on your computer hard drive and check the performance. I expect that you would have the kind of performance I'm seeing.
Mathieu
Hi Mathieu,
Thanks for testing. During
This machine is a Dual Zeon 2.3Ghz with 32 GB with solid state primary. I have two 1TB western digital blacks connected directly to sata ports The Idea was to read from one and write to the other. Running multiple instances doesn't seem to bother this thing as far as operational speed.
I wrote a script to log the file size every half minute. The script and results are in the attached zip. (The script is in AHK and readable in a text editor.) @395.5 minutes the file size spiked and then slowed to a crawl thereafter.
Note I started the logging script a few hours after it began the merge operation so 0 minutes is actually some time after it had began the merge operation.
I'm going to kill it now as it looks like its going nowhere.
Re: trying a smaller merge.Yes. we do smaller merges without issue. Just this job is huge!
When the process takes a long time anyway it sure is difficult to trouble shoot.
I'm wondering if your solid state primary is not stealing all the speed on your bus. Also maybe the motherboard has been built so the solid state can interrupt the SATA disks, which would explain why you are not experiencing any lagging while working during the Merge.
In any case even at the beginning of your script 45 Mb per minute seems awfully slow compared to the 2500 Mb per minute on average up to 37 Gb!
My last advice would be, find a computer without a solid state, and plug the two SATA (or even better, use only one SATA) and retry the merge. My guess is that in 6-7 hours the Merge should be complete.
Actually in that test I used LZW compression on the output. Sorry to confuse things.
Using uncompressed output I get a much faster write initially but then it slows down.
During the fast write speed there is no actual reading of the source images! So what I believe happens is that when writing uncompressed the file gets created first (like a blank image) and then the data is added to it.
You can confirm this by using windows resource monitor. filter by system and ustation and look at the file reads/writes on the drive. The source images are not read until the file reaches it's maximum size. It is this second phase that seems to take a long time ( the actual transfer of the data from source to destination image).
So in your test you probably stopped it before there was any transfer of image data.
Ah ok, now I see, you seem right, the destination raster is first written with background color (which when using LZW compression of the size of the destination raster is very small pixels with same color can easily be compressed).
So using the size of the raster to evaluate the progress is not possible thus, even more when the destination data is uncompressed.
I let a 23 GB uncompressed export run till the end and it takes about 7 hours.
I am not sure why the performance bottleneck is so I have entered Defect 114991.
