MicroStation 08.11.09.459 vs 08.11.09.578 or 08.11.09.608?
Is there a disadvantage of installing 08.11.09.578 or 08.11.09.608 on all users computers compared to 08.11.09.459 even if some users are not in need of products such as InRoads, Descartes, etc.? We want to push only one version of MicroStation SELECTseries 3 through our SCCM system and not have multiple options for SS3. So the question is, would there be an issue with all users running 08.11.09.578 or 08.11.09.608 and skipping over the SELECTseries version ( 08.11.09.459 )?
Thanks, SMagoon
  • It is suggested that if you are not running any vertical products such as Inroads or Descartes that you install the commercial 08.11.09.459 build. The other builds are specific to the verticals and those version are needed to run those products. If some of the machines will be having a vertical installed then it is suggested that you install a version of Microstation that will run with both of those vertical products. This way only one version of MicroStation will be installed.
Reply
