Restrict access to system command propmt
We have restricted use of the run command within Windows and hidden the C drive from users within explorer however users can fork out to a command window within Microstation by using the ! or % key-ins. This gives them access to the hidden C drive etc. Is there a way to restrict the use of the ! and % key-ins to stop users from bringing up this system command window?
Colin
Parents Reply
  • Hi,
    Restricted access to the run command is via group policy as is the hidden c drive within windows explorer. You can't even enter c:\ within explorer. If you use the ! Keyin in Microstation then you can get to the c drive within the command prompt. I'm not from IT but a power user for CAD it is IT that has asked me the question to see if the keyin can be restricted.
    I didn't know if there was a Microstation variable to restrict the ! Keyin but it seems not. It looks like a command filter application is the way to go.
    Colin.
