Is it possible in Project Explorer to add a link to design models but filter on a specific model name
I've set Project Explorer up to show all Designs in Project.
Link Type: Configuration Variable Link
Link Name: Designs
Configuration Variable: MS_DEF
Filter: Model:Design
This is all standard stuff shown in the default example installed with MicroStation.
What I would like to do is filter such that I only see the models named "Default".  Is this possible?
The reason I would like to do this is the dgn files have a bunch of different scale models in them that are not used.  I have to wade through hundreds of models from all the dgn files that are not used to get to the default models.
As much as anything I'm curious if this is possible.
Mike
