MicroStation configuration
Can someone describe what the following does:
 "BLOCKED SCRIPTvoid(null);" "-wsMY_FILE=%1" "%1"
Does this stop normal configuration script processing and replace with the following only? "-wsMY_FILE=%1" "%1"
  • Hi Gary,
    I see three different parts in your question.
    It's not quite clear what BLOCKED SCRIPT does. Or was something originally different blocked when posted to this web?
    What is clear is -ws argument. It's used to define MicroStation configuration variable when MicroStation started, so it should not be define at Windows level or in some MicroStation configuration file. -wsMY_FILE=%1 create a configuration variable named MY_FILE and sets it to the value of the first parameter used when batch is started. Because %1 parameter is used, I suppose your example is from some bat file?
    Last "%1" takes the first argument used when batch file was started and pass it to MicroStation as a design file to be opened.
    I guess not, but it can depend on you workspace configuration and Windows environment.
    With regards,
      Jan
  • Thanks for your response Jan. My question was initially to the document author and really revolved around the statement "BLOCKED SCRIPTvoid(null);" as mentioned in the referenced document. I see it is separated by the semi-colon, which indicates/represents a separate key-in. Thanks again.
Reply Children
