MicroStation 08.11.09.714 build does not install/upgrade properly from the .65X point release builds.
Installing issues. After uninstalling previous version, and then install 714 build, MicroStation doesn't actually install. It doesn't show up in programs in the control panel either.
Prior to installing Inroads 08.11.09.845, the only solution we've found is to uninstall MicroStation and Inroads completely, and then manually delete the MicroStation folder. Even when we do this, we sometimes still need to reinstall MicroStation twice, prior to installing Inroads. Something is wrong with this installation routine.
Parents Reply Children
