Hi, folks. I'm looking to create some ribbon buttons in a dgnlib file and load it via MS_GUIDGNLIBLIST. The loading works fine. The question I have is about how to get rid of old button definitions that I created and no longer want anymore.
VERSION INFOMicroStation CONNECT 10.0.0.25
STEPS TO REPRODUCE1. Open the dgnlib pointed to by the MS_GUIDGNLIBLIST variable in MicroStation.2. Right-click on ribbon and choose "Customize Ribbon".3. In the Customize Ribbon box that appears, create a new ribbon tab on the right. I've been using the "Drawing" group for this.4. Create a group in that new ribbon tab.5. Create a button in that ribbon.6. Now observe that that ribbon button's name shows up over on the left in the "Choose components from:" list. Okay so far.7. Delete the button you just made on the right. Let's say you're deleting it because you changed your mind, decided to go in a different direction, whatever. Button is deleted on the right. Push {Apply}. Even exit MicroStation if you want.
THE PROBLEMNow comes the problem that I don't know how to solve: The now-deleted button is still listed on the left, in the "Choose components from:" list. I have some buttons I tried creating a few times and they're all over in that list, cluttering it up.
How can I get entries for already-deleted buttons removed from the "Choose components from:" list in this Customize Ribbon box? Is there some key-in to purge these? Compressing the dgnlib (with all checkboxes on) did not get rid of them.
Thanks for any help you can provide.
File a Service Request, and reference the Enhancement number. Add your name to the petition to get it included. That's all I know.
MaryB
This enhancement is still open, if you file SRs requesting that we address the matter it will increase its prioritization. A number of parameters are involved, it is not just the SR count, but the number of SRs linked to a defect or enhancement is one indication of demand.
Marc
Thanks for the replies everybody. I filed a SR #7001085080 and have received a seemingly cookie cutter response, added to the list of requestors and we'll let you know if it gets added.
Chris Thorp
CADD Applications Support Coordinator
Production Support Office / CADD
605 Suwannee St, Mail Station 69
Tallahassee, FL 32399-0450
Support Email: CADD.support@dot.state.fl.us
Hi Chris,
The initial response will be standardized, I've added a link in the SR to this thread so the dots are joined.
