Microstation CONNECT customize ribbon workflow
Is there a way to setup a workflow that will invoke a command, set a configuration variable or other action when the workflow is selected from the drop down list by the user?
For example.
DGN has 2 models (Test1 and Test2)
Workflow drop down has 2 workflows (Test1 and Test2)
When user selects Test1 the Test1 model becomes active model and if Test2 is chosen then Test2 model is active model
Parents Reply Children
