[CONNECT] Named Expression with Compound condition
Have I done something wrong or is there a problem with Named Expression that contain compound conditions in CONNECT?
I have a Ribbon Group that I want to show only when one of two models are active (aplan or Sheet1)
I have the two models within my dgn yet my group only shows for the first model when its active not the second. When I test the conditions inside the named expression dialog both return true.
Screen shots from my DGNLIB are included below
Any help will be greatly appreciated
named expression syntax
Group Visibility property
Parents Reply Children
