When setting up a custom workspace by setting the _USTN_CONFIGURATION to the new location in the shortcut, I have noticed the example files are still visible from the original workspace install location.
How does one get rid of this from the startup dialog using configuration variables?
_USTN_INSTALLED_CONFIGURATION is a variable that points to a path by default. By setting it to 0 you are making it not found. You could set it to Null and <blank> and do the same.
~HTH
John.
yep
Yep, that works. Nice one.
Marc
