This is what you expect to see when customizing MicroStation CONNECT's UI...
I'm trying to edit some tools that I created a few weeks ago (using CONNECT Update 4), but in CONNECT Update 5 all the buttons in the Customize dialog are greyed-out and a right-click is no better. What could cause the UI editor to become passive and unusable? Surely not a version difference?
To put the question another way, what are the pre-conditions for successfully editing a custom toolbox or workflow in CONNECT Update 5?
Answer Verified By: Jon Summers
Unknown said:Do you use a UNC path in MS_GUIDGNLIBLIST to point to the dgnlib?
I had configured the workspace using a UNC path...
_USTN_WORKSPACEROOT = //Asterix/DataDir/Bentley/CONNECT/$(_USTN_WORKSPACENAME)/
Following your suggestion I changed that to a mapped drive letter...
_USTN_WORKSPACEROOT = L:/Bentley/CONNECT/$(_USTN_WORKSPACENAME)/
Now I can edit my custom UI. Thanks!
Marc
Unknown said:Please can you confirm that the dgnlib in question is included in MS_GUIDGNLIBLIST in both UNC and mapped cases?
Yes. My post shows the only difference is the use of a UNC in the config. file.
Unknown said:Did it work with the UNC path in Update 4?
I don't recall, and because U5 overwrites U4 I can't test.
Unknown said:At what level in the configuration is the DGNLIB included; Organization, WorkSpace or WorkSet?
As the example shows, it's any and all of those because the path is defined early on in the config. process.
