_USTN_WORKSPACEROOT = //Server/Root/Bentley/CONNECT/$(_USTN_WORKSPACENAME)/
Using a UNC path in a workspace folder specification makes some tools read-only (see this post) when using the Customization dialog. Changing to a mapped network drive letter enables editing...
# L:/ is a mapped Windows drive as //Server/Root/ _USTN_WORKSPACEROOT = L:/Bentley/CONNECT/$(_USTN_WORKSPACENAME)/
Bentley Systems: is that intentional? If so, please clarify why using UNC paths in configuration variables doesn't work as we might reasonably expect. If not, please change the configuration file processor so that we can use UNC paths.
Unknown said:let’s start by looking at some diagnostic data
Please look at this thread in MicroStation Admin. You'll find evidence already submitted.
