Dgnlib modification
I have gone thru and searched for the answer to this question on best practices to modify a dgnlib.
When modifying a dgnlib file is it best to:
Wait until after normal business hours when everyone is out Microstation to open and modify a dgnlib file?
Copy the dgnlib to either another named dgnlib file or should it be a dgn then, modify the dgnlib / dgn outside the normal workspace and restore it back to the previous dgnlib file name (when everyone is out of Microstation)?
I have read that to export the dgnlib file with levels to csv. Modify csv file and re-import csv into dgnlib. (so what about tool customization or templates?
Just trying to figure out best practice to modify a dgnlib file. My guess is to always open and modify a dgnlib file after hours when, nobody is using Microstation from the workspace that has the dgnlib configured.
  • It is best practice to manage dgnlib files outside the day to day working configuration. One method is by using an administrator User Configuration file containing appropriate variables.
    For instance I have one that I have used in the past called NoDGNLIB.ucf that contains the additional variables:
    MS_DGNLIBLIST = Setting this to null stops DGNLIBs loading so it is easier to see what is in the DGNLIB you are working in
    MS_GUIDGNLIBLIST > $(_USTN_USER)*.dgnlib This adds the admins _USTN_USER folder as configured location for UI DGNLIBs so you can play around without anyone else seeing the work in progress. MS_DGNLIBLIST = will need to be commented out (or just have another UCF) for UI customisations to be able to see site resourecs.
    _USTN_DISPLAYALLCFGVARS = 1 Shows systems variables as well as user variables. This can also be set as a Windows Environment Variable for admin users.
    The following two are needed if editing print configurations has been hidden/disabled
    MS_PLTFILE_EDITOR = MicroStation To override MS_PLTFILE_EDITOR = hide_menu_item
    MS_PLTDLG_ENABLE_SAVE_CONFIG = 1 If MS_PLTDLG_ENABLE_SAVE_CONFIG is set to '0', the plot dialog save configuration menu items are disabled.
    MS_VBA_OPEN_IN_MEMORY = NONE needed to allow editing of organisation VBA if it is set elsewhere in the configuration as MS_VBA_OPEN_IN_MEMORY = ALL
    Hope this is helpful!
    Marc
Reply
    Marc
