Hello everybody,
I just started using Microstation and was reading a manual. The manual have things that are not similar to my edition (Microstation CONNECT Edition, Update 5) and I got an : i wanted to add to the ribbon the "Change Text Attribute" button. It was there already, but not showing, so I decided to add the button again and now this shows up:
As you can see, now that and "Match Text Atrributes" are both underlined (yes, I also tried with that one). ¿Do you guys have any suggestions?
Thanks.
Hi Christian,
I agree with Carl it's probably caused by a disorder in your GUI dgnlib files and in what file what customization was done.
One you dialog was captured with Personal.dgnlib opened, the second one with MicroStation_Basic.dgn and it's not clear whether the same workspace / workset configuration was used.
When you use Revert All Ribbon Customizations tool, it depends what file is opened:
You should be aware that the same ribbon object (e.g. tab) can be customized from different dgnlib files, so when editing existing customization, you have to open the righ dgnlib (or to be in a general file for personal.dgnlib modification). The source of customization is displayed in Customize Ribbon dialog when you hover over the customized object.
With regards,
Jan
Answer Verified By: Christian Acevedo
Yes, both of you were right. I had to move to that library in order to run the modifications. Thanks!
