I am trying to troubleshoot why one project will not recognize our standard networked directory of TTF.
The configuration variable should be MS_FONTPATH, correct? or am I mistaken?
These are fonts that come with a special software package. We don't want to copy them all to everyone's machine, preferring instead to store them centrally on our server. And I would swear that every other project sees them just fine...
Thank you.
you are correct MS_FONTPATH is what you need. I would compare a project that is working to the one giving you trouble (compare DEBUGS)
Timothy Hickman
Main: 877 627 3772|
Answer Verified By: MaryB
Yep, found it. Misspell one little directory name...
Thanks!
MaryB
Unknown said:Misspell one little directory name...
We wrote the Configuration Variable Validator to help with that problem. It's freeware.
