I have DGN files referenced into our sheet files and I am able to turn its levels on and off. I "Save Settings" before I exit. But when I re-enter the sheet file, the levels that are turned on and off have reverted back to what they were previously. Is there a variable or setting that will allow MicroStation to hold those level on/off settings?
I am using MicroStation V8i SS2 (Version 08.11.07.443)
look at the attachment settings for the references and tell me what the "display overrides" option is set to.
Timothy Hickman
Main: 877 627 3772|
ok - try keying the following "set refleveloverrides" and tell me what the message center shows.
are you in a custom workspace ? if yes, then what happens if you use a delivered out of the box workspace does the issue still occur ?
