I'd like to modify the MS_DESIGNSEED variable but it seem to be lock. How to unlock it?
Emilie
You may have to find the file it is defined in and edit it there with a text editor
MaryB
It looks like the variable was locked in the users .cfg file. If you do not know how to find it or for some reason it isn't locked in that file you may find the following useful:
https://communities.bentley.com/products/microstation/w/microstation__wiki/11081/how-to-quickly-generate-a-debug-file
https://communities.bentley.com/products/microstation/w/microstation__wiki/24841/how-to-lock-a-configuration-variable
It's working! Thanks!!!
