We are moving the SELECTserver & DB to new servers. Have installed SELECTserver ok, and a DB has been created. When using the SELECTserver Database Setup, we can select the server/DB ok, when we 'click' OK, an error message pops up:"Access to Path 'C :\Program Files\Bentley\SELECTserver\App_Offline.htm' is denied"There is no file of that name in the folder? I have checked the current server/folder and its not present either. Any ideas?
That usually indicates a permissions issue. It is possible that it is hidden and you do not have the permissions to view it and it sounds like that directory is read only.
